BFL13
Dec 23, 2013Explorer II
IMO it is more likely SOC will be in the 90s when absorption starts, due to the low charging rate. Solar has low amps compared with the usual converter size amps, so where you might be at 80% with the converter, it would be much higher in SOC with solar on the same size battery bank.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
