pianotuna
Dec 23, 2013Nomad III
Hi BFL13,
How does the controller know to "back off"? The only measurement it can check is voltage. The controller doesn't know if it is charging 1000 amp-hours or 10 amp-hours of battery bank.
It may be that absorption voltage has a higher voltage set point (or can be so adjusted) in a solar charge controller--but if is not then it would seem logical to me that the set point would default to 80 to 85% state of charge, just as if it were a converter doing the job.
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
