- anon125ExplorerThanks for your input
- cwitExplorerGrease is more important than oil. If you ever get a frozen kingpin you will believe this. I do mine about 3,000 miles or twice per oil change, witch is at 6,000 miles.
- anon125Explorerthanks
ford does not reply. no surprise there! - Dutch_12078Explorer III
anon125 wrote:
Thanks everyone.
Now we need a chart to show the independent mechanic where they are for a 2006 ford chassis!
These might help...
- BrianinMichiganExplorer
MEXICOWANDERER wrote:
Chassis lubing is soooooo.......YESTERDAY
Obsolete like doing a convergence on a color tv set
Almagard 3752 is to grease what DeOXIT D100L is to electronics cleaners.
Or Woolrich clothing is to Wal-Mart rags...
I pack bearings, After 10 years 100k miles they look like they were done yesterday. Same for ball joints, tie rod ends, driveshafts, etc.
I still have my color bar generator and my Sencor VA48 analyzer along with my Heathkit VTVM:B - anon125ExplorerThanks everyone.
Now we need a chart to show the independent mechanic where they are for a 2006 ford chassis! - SidecarFlipExplorer IIIMight be yesterday but yesterday lasts a long time. Today with plastic inserts and a dab of grease equals premature failure. Roads are worse, suspensions take a pounding, alemite fittings and quality teflon based synthetic grease is the recipe for longevity.
I have 23 fittings on my F350 pickup underneath. All get greased every oil change. - BarabooBobExplorer IIIIf the chassis has grease fittings, they should be lubed at every oil change. Use a high quality grease and put in just enough to get the rubber boots to plump up just a little bit. Do NOT put in so much grease that you can see it come out around the boots. The boots are suppose to be a pressure system that pushes the grease back into the joint.
- wildtoadExplorer IIYes chassis lubing is yesterday technology for most vehicles. Unfortunately not so for Ford F53 based RVs. There are 10 fittings (I think).
- MEXICOWANDERERExplorer
Having RV issues? Connect with others who have been in your shoes.24,349 PostsLatest Activity: Jan 12, 2026
