- fj12ryderExplorer III
time2roll wrote:
I'll have to agree with this strategy. IMO every year is just silly, and either mostly wasted labor and/or money.
By the book once a year.
IMO the first repack should be done within two years. Once you are certain the pack was done properly I would go at least 5 years or 30,000 miles. Just did mine at 10 years when installing disk brakes... all was fine. - 2oldmanExplorer II
- By the book once a year.
IMO the first repack should be done within two years. Once you are certain the pack was done properly I would go at least 5 years or 30,000 miles. Just did mine at 10 years when installing disk brakes... all was fine. - DougEExplorerUnless you immerse them in water, pull the cap once a year. Leave it alone if the grease looks reasonably fresh.
- IvylogExplorer IIIMy DW says I own too many trailers...more than 10. In the last 10 years I can only remember doing one...maybe because it was last month and only on one side of a boat trailer. I do remove the caps and it t grease has hardened I fill the cap with 90 weight gear oil and put it back on quickly. If the trailer is to heavy to wiggle the tire I will jack it up so I can check the bearing adjustments.
On the subject of tires...I only buy used LT takeoffs (5-7 tread left and less than 3 years old) for my smaller trailers.
PS: I've only been doing these things for only 40+ years so time will tell if it works.:B - BusdriverExplorer IIHow often do yOu repack your car bearings
- SmaxExplorerThe shop I use said it is more of a function of use. Contrary to what you might think he said that they should be re-packed if the RV has been sitting a long time. He didn't define long time....
I do my own. Some years we only do local trips. I always do them during the years we have a big trip planned.
I keep a spare set of bearings and seals in my RV toolbox....
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Jan 12, 2018
