- grizzzmanExplorerWell we are on I80 doing 85 (wife is driving) And i "hope"my panels are still on. Good test i guess o and 45mph side winds.
Well we made it to camp. I made the panel brackets 3/16 T6 aluminum 3"angle (panels are 6" off the roof) 3 #10 screws per bracket dicor glued. - SFVdaveExplorerFrom the OP,
I have a filon roof too. I want to put a 150 watt panelon the roof. I have the room and access to the refrigerator vent nearby for wiring. Just worrying about the best way to mount a larger panel like that with just 4 or 6 Z-brackets and those short screws that the kits come with. - tpiExplorerOn my aluminum roof MH I used the 3M 5200 with eight brackets on a 100 watt panel-no screws. This was suggested by Lazy Daze factory even though the factory installed panels have one number 10 screw per foot. So far so good-up to 70 MPH with a headwind. This stuff really holds-but give it some time to cure before subjecting it to high speeds. I didn't put any real speed on it for a couple weeks. It is not something you want to do a day or two before your vacation.
- brulazExplorerRather than the tape or epoxy, with something like Filon, I would try 3M 5200 Marine Adhesive caulk with long (or lots of) brackets giving you lots of surface area to adhere to. Could drill holes in the brackets so the 5200 wells up into the holes. And would need weight to hold the brackets down while it dried.
Don't think screws would be necessary as that 3M 5200 is basically permanent. Pretty sure the Filon would rip out before the joint. - AlmotExplorer III
2oldman wrote:
As long as you have a 1/4" sheet of wood you'll be fine. This isn't wind tunnel testing.
Yes, but it could be 1/8" ply. In a 1/4" ply I would use 2 or 3 screws per bracket, with at least 3" spacing between screws. Ex., a 6" long piece of 3x3" aluminum angle with 2 or 3 screws, per corner.
DAS26miles - yes, a long bracket that spans the whole length of panel like on the Dusty's photo, would work. In 1/8 ply and with a long bracket like this, I wouldn't drive too many screws . Not "every few inches" for sure. Epoxy and 4 or 8 screws total should be enough. If you can locate rafters, it's always a good idea to drive screws in there. - 2oldmanExplorer II
So a filon roof is a problem I guess. Would a long l bracket screwed in every few inches work or would I have to screw thru thre roof and put washers and nuts on bolts? I don't thonk the DW would go for that. - DAS26milesExplorer IISo a filon roof is a problem I guess. Would a long l bracket screwed in every few inches work or would I have to screw thru thre roof and put washers and nuts on bolts? I don't thonk the DW would go for that.
- BruceMcExplorer IIIHeck, I've poked along at my normal 60-65, then done 90 trying to catch up with my brother who generally drives 75! It was the first test on those panels... they never budged.
Of course, they are glued & screwed to the roof/every cross-member I could find...
Link to (dusty) pics of Solar Install , for those who haven't already seen it....
We were in 40-50mph quarter winds in NE Colorado at 70 mph; steering wheel turned 30-45 degrees into the wind just to keep 'er rolling straight down the hwy. It was a white-knuckle trip... Those panels were on my mind the entire time, right along with the awning. Neither came loose.
Enjoy! - AlmotExplorer III
DAS26miles wrote:
My DW doesn't want me on the roof, so this may be a moot point. But I have filon too. What would I do to secure it, screws and dicor only?
Filon is different from rubber on 3/8 ply. In Filon you only have 1/8" ply, with (probably) block foam underneath. Regular tapping screws won't work. I would not rely on Dicor in this case and would rather use epoxy or VHB tape. Some people use well nuts in addition to Dicor (then Dicor becomes necessary to seal around the well nuts).Also, do the roof mounted panels keep your batteries charging and or topped off while driving?
Solar works all day long. People don't turn it off for the night, or when they go fishing, or when driving. - 2oldmanExplorer II
DAS26miles wrote:
Unless the wind can somehow blow away the sunlight, yes.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
