DrewE
Sep 28, 2017Explorer III
Is this a sliding window, or otherwise openable? Is the weep hole clear?
In general, the rubber surround is not expected to hermetically seal an RV window. Any water that sneaks past it is intended to drain through the weep hole; that's what the weep hole is there for. (Sometimes in fixed windows they have no weep holes, but even there the actual water sealing is typically the adhesive holding the glass against the metal frame on the inside, and the rubber surround is for appearance and some physical support. It's a little like a car windshield in how it's sealed and mounted.)
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 01, 2026
