MrWizard
Sep 28, 2017Moderator
have you done a water hose test
mildly spray only the bottom half of the window
does water get in the track with the glass and leak inside,
or does it come out the weep hole
next try the top of the window frame ?
if the glass is loose in the track and not making a water tight weather seal
it could be a choice between permanently sealing the glass to the outside (not opening)
or getting a replacement window
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jun 30, 2026
