cj7365
Jul 28, 2015Explorer
BFL13 wrote:cj7365 wrote:
I have 3 ea, 55 watt, 3.5 amp solar panels, what is the best way to connect these together. What gauge wire do I need.
I would like to use connectors that I can take apart, this will NOT be a fixed system on the roof.
I do have a controller.
It works better for amps to the controller if you feed each panel's wires to a common point (which could be the controller itself) instead of connecting panel to panel and then run wires from the last panel to the controller. Not a huge amount, but it does make a difference.
MC4s make a good quick connect, but you need long enough finger-nails to squeeze them apart. Wire nuts work, but can get frazzled after a few times. Anderson makes some other types.
ok, will have to look to see if I can put 3 wires into the controller socket, might be too thick.
Thanks for the tip on the MC4 connectors
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
