MrWizard
Aug 19, 2015Moderator
I don't believe I suggested that
His tt is at home
I said to check all the ground wires on everything
Then said he could add an 8ft *code* copper rod
As an accessory ground at the trailer
And No he would not get zapped clamping the cable to the trailer
He being a much higher resistance path to ground than the rod, would be highly unlikely to get anything from that low level leakage, with the low resistance copper circuit there
His tt is at home
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
