Bandaid
Sep 06, 2022Explorer II
Discovered a serious problem
Hello,
A year ago my wife and I purchased a 2021 Forest River SunsSeeker Classic, class C camper. It now has 5400 miles on it and is less than two years old. Yesterday, while washing the camper I bumped a piece of trim on the bottom edge of the bulkhead panel between the cab and the camper living area. The trim piece fell off onto the driveway and a bunch of what I thought was sand and dirt came with it. Inspecting the trim piece, it looks as though the factory installed it with one screw. The serious part is that the wood, probably either OSB board, or chipboard, sandwiched between a thick layer of sound deadening foam and the fylon outer skin is wet and rotting! Same thing on the drivers side and in that case, the trim piece is laying along the side of the road someplace!
I'm wondering. Have others had this problem with not only Forest River products, but other class C's. If so, what have you done to fix the issue, DIY, or was it taken to an RV body shop?
Bandaid
Bandaid
