Baja_Man's avatar
Baja_Man
Electric Entry Step motor...Problem discovered!...with pics
I have a Coach Step # 725-0051. It stopped working. The motor runs but step will not stay put. It will slide in and out freely after motor stops.
I removed the motor and opened up the insides. I have attached pics with text to explain what I believe to be the problem. To summarize...I believe the cog into which the gear sits into and rotates, is worn out. Being worn out it allows the gear to spin freely when it should remain snug in the hex shaped cog.
