Ron_Nielson
Aug 19, 2015Explorer
Harvard wrote:
Can we assume the voltage from the RV chassis to earth is the same as the RV chassis to the car port?
There is some difference in the readings between the earth/dirt/mud under the trailer on the one hand and the carport vertical structures (2 1/4" square tubing, mounted on concrete piers sunk 4' into the ground). The readings to the carport are higher.
Harvard wrote:
Also, is the RV tongue jack making a conductive path from the RV chassis to earth or is it sitting on a non conductor?
The 5th wheel landing legs and also the rear stabilizers rest on 13" tall wooden guard rail timbers, then on concrete block on top of the rock which covers the entire carport and approach area. So very little conductive capacity there.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
