MEXICOWANDERER
Aug 20, 2015Explorer
Señor I may be at a disadvantage because even a single flashlight battery will rudely tingle the skin on the inside of my forearm when the skin is damp. Not a slight tingle either. The human body is weird. Not all individuals are built the same.
But, I heartily agree with your source of origin diagnosis. Correctly earth grounding the RV will result on 0.00 volts when disconnected or connected.
Place a spiral of magnet wire beneath a high tension power line and two things will happen. The coil of wire will develop a surprising amount of electrical power and secondly if discovered, the utility will indeed criminally prosecute for theft of electricity.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
