SaltiDawg
Jun 11, 2017Explorer
profdant139 wrote:
If you have access to ethanol-free gas, you can probably stop reading -- it does not gum up the carb like ethanol does. And if you use your generator every week or so, stop reading -- you do not need to drain the carb, since frequent use also prevents carb problems....
Also, if you have converted your generator to run on either Propane or NG, certainly stop reading.
Having RV issues? Connect with others who have been in your shoes.24,384 PostsLatest Activity: Apr 29, 2026
