profdant139's avatar
profdant139
Explorer II
Jun 10, 2017
How to drain carburetor on Honda 2000 -- short video
Believe it or not, there are folks who do not know that they should drain the carb on a generator before putting it away for a long time, and folks who do not know how to drain it. (I was one of those folks, until my local mechanic took pity on me. It cost me a couple of expensive trips to the shop before he decided to derail the gravy train.)
If you have access to ethanol-free gas, you can probably stop reading -- it does not gum up the carb like ethanol does. And if you use your generator every week or so, stop reading -- you do not need to drain the carb, since frequent use also prevents carb problems.
But I am here to tell you from painful personal experience that even if you "exercise" your generator every month (by running it under load), and add Seafoam (which is great stuff), you can still gum up the carb if you do not drain it.
I did a search on Youtube for "Draining the carburetor bowl on a Honda 2000" and they displayed a lot of long videos on carb maintenance (taking it apart and so forth). There was nothing short and simple.
So here we go -- maybe call it "carb draining for dummies like me!" (Do we need a separate "tech impaired" forum, and leave the real tech forum to the experts??)
Short video on draining the carburetor on a Honda 2000
  • One follow-up comment -- you can see in the video that the generator is raised up off my workbench on 4x4 blocks of wood, so that I have room to slide a cup under the drain tube to catch the drips.
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
