Bumpyroad
Apr 25, 2015Explorer
Old-Biscuit wrote:
The pressure needed is just enough to overcome the spring in the check valve assembly inside hose connection.
and I discovered that you should open a faucet to remove water pressure before trying to force water into the system thru the city water fill.
bumpy
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
