DAS26miles
Apr 25, 2015Explorer II
PNichols wrote:
A bit off topic, but .... in addition to a gravity fill fresh water tank, how about a fresh water tank gravity flow emptying valve coming conveniently out the sidewall of the coach?
The reason for this is - if the water pump should ever fail while on a camping trip - you can still get at the fresh water tank's supply for drinking, cooking, toilet flushing, etc. without having to find and install a new water pump or terminate the camping trip.
That's a good idea! Also, when I get home and dump my fresh water tank or flush it, I can attach a hose and water my plants. Now, it runs down the driveway. Not legal here in Los Angeles anymore. I will have to crawl under the MH and replace my existing plastic fresh water tank drain hose. It's in a bad spot and drains onto the frame. Hope if I get a new MH there is a better system.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
