Hurricaner
May 14, 2015Explorer
Dave, as long as there are two separate controls on the water system you can just put one in the winterize position and the other in the fill position, then use the hose for sucking antifreeze to suck fresh water from jugs. Most motorhomes are set up this way but I suppose there are exceptions. I have a gravity fill but installed the valving to make this happen many years ago and have never used the gravity fill while boondocking. It is so much easier to use the pump then trying to empty jugs into the fill hole.
Sam
Sam
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
