Salvo
May 28, 2015Explorer
You should be able to fill the tank without that small hose.
1. Turn the "Normal" water fill valve to "Tank Fill".
2. Turn the Winterizing knob from "Normal to "Winterize".
3. Place clear hose by winterizing knob into axillary water container.
4. Turn pump on.
If I want to take a inside shower using the water in a solar shower bag then I use steps 2, 3, 4.
4. Turn pump on.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
