SCVJeff
May 28, 2015Explorer
Salvo wrote:Sure, and good idea, I hadn't thought of that.
You should be able to fill the tank without that small hose.
1. Turn the "Normal" water fill valve to "Tank Fill".
2. Turn the Winterizing knob from "Normal to "Winterize".
3. Place clear hose by winterizing knob into axillary water container.
4. Turn pump on.
If I want to take a inside shower using the water in a solar shower bag then I use steps 2, 3, 4.
You are missing the return path to the tank. There are only two ways to fill the tank: gravity fill, and street hose port. So that hose simply links the pressurized side that would normally draw FROM the tank, but now obviously not with the other valve set in Winterize mode, is drawing from the jug.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
