Dutch_12078
May 28, 2015Explorer III
When I relocated the water pump in our Landau shortly after buying it, I also added a suction fill setup that can be used for both winterizing and adding water to the fresh tank. The three way valve at the pump is used to select the suction hose as the pump inlet, and the normal fill valve on the panel is used to select fill or winterize.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
