SCVJeff
May 28, 2015Explorer
wnjj wrote:well clearly you're right, I'm having a hard time understanding why it's built like that?SCVJeff wrote:SCVJeff wrote:well I do believe you're correct. It does draw out of the jug but appeared to be slower than with the hose but the tank overflowed before i could really figure it out. Gonna oull the drawings tonight and see how that works. Thx!Salvo wrote:Don't understand how it could, but I will, maybe today
There's a third way Jeff. Directly from the clear winterize hose when the "Normal" valve is turned to "Fill Tank". Your little hose is not required. Give it a try!SCVJeff wrote:
But there are only two ways to fill the tank: gravity fill, and street hose port.
All the "fill tank" valve does is connect the pressure side of your system to the tank, just like your outside hose does. Normally the pressure to fill comes from the city water hose but it can come from the pump via the winterizing tube just as easily,
I got the hose idea from several members here and it makes sense, but not this.. What's the point?
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
