Dutch_12078
May 29, 2015Explorer III
The check valve shown between the tank and the pump is part of the pump. My setup looks like the drawing except that the fill valve simply bypasses the pump and connects the selected fill source to the bottom suction port. The tank drain valve uses the same port. The only other port in the tank is the vent at the top.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
