7_3_psdman
Oct 06, 2017Explorer
I did find the kitchen faucet leaks at the base where it pivots. That should be an easy fix- new faucet set. One side of the sink drain leaks under the strainer and I am trying to take it loose so that I can fix it right. Is there some trick to holding the strainer so that it doesn't turn while you use some kind of giant spanner on that locking ring?
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
