samsontdog
Jun 13, 2014Explorer
More To See wrote:
It seems like everything is working against you. Both high altitude and hot temperatures.
Using the rule of thumb of 3.5 percent loss of hp for every 1000 feet of altitude (6300 feet) you lose about 22 percent of your hp.
So if that also equates to a 22 percent loss of power then your 3 kW Honda becomes a 2.3 kW generator.
Now add in some more power loss due to the high temperature of air going through the carb and you are probably getting very marginal.
And perhaps even more loss due to the engine running rich if there is no high altitude adjustment.
Thank you ! This is what I thought. My power cord from my TT is only
30 ft long and I run my heavy Honda 3000 from my tailgate with another
30 ft 30 amp cord. I sure don't want another 3000 Honda. Guess I will go back to two EU2000
Again, THANKS EVERYONE
The only other thing I could think of is to use only a heavy gauge very short power cord (and upgrade those start capacitors as previously mentioned).
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
