wa8yxm
Jun 25, 2015Explorer III
For the Ignition on lead you can pick up power from the dash radio lead, Or the aux panel (if you have one) your battery control center (Should have spare fuses marked IGNITION) or chassis main panel
For house batteries you can use a relay powered by the above wire you tapped.
That is the best I can do.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
