maillemaker
Jun 25, 2015Explorer
For the Ignition on lead you can pick up power from the dash radio lead
Yeah! That should do it!
As it turns out, these battery gauges have a 3rd contact built in that when de-energized turns off the gauge. So I did not even need the relay. I just need to find an ignition-hot and send it to the "C" contact on the gauges. Then the + and - from the gauges go through a fused lead to the respective batteries.
Steve
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
