Ruralgas
Jun 23, 2022Explorer
Hello:
Spend the time and clean all the caulking with a solvent on a small cloth. Inspect the present caulking for cracking, gaps or coming loose and remove suspect area/s, then reapply self levelling Dicor on that area. Apply a good amount for good coverage/sealing. If the gap is large, you may have to apply a couple coats.
Do a very complete inspection and resealing and you'll be good to go.
You can soak your roof to check for a leak or leaks, but like said before, the water will travel. That's why you're much better off to do the cleaning and resealing.
Just my personal experience.
Good luck.
Good luck.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
