TurnThePage's avatar
TurnThePage
How to ground FM antenna?
I'm adding a "real" antenna to my travel trailer. I'm mounting it in the center of the roof, which is rubber on plywood. It has a ground strap which ideally should be grounded to the frame. That would take a fair amount of work. What are the drawbacks from using the 12v ground connection for the stereo?
