MEXICOWANDERER
Jul 14, 2015Explorer
the bear II wrote:
Most RV roofs are strong due to a process used to pressure seal the inner and outer panels along with all of the insulation together using glue and a vacuum process. This creates a strong platform which distributes weight across the roof. You would have to drill through the roof and put a plate on top of the roof to spread the weight across the roof. Anytime you penetrate the roof you create the possibility of a leak. There aren't the typical rafters to screw into like in a home.
Your best bet would be to use a stand like this
http://www.yogaswings.com/
Or have something built to fit in the area of your RV.
X2
Collapsible. Can be disassembled etc. Prospective buyers may balk when they see patched holes.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
