profdant139
Jul 15, 2015Explorer III
Here is a work-around -- using steel 2 x 2 perforated square tubing (available at the hardware store), build two side support structures in this shape:
_____
Anchor the vertical supports to both walls using plastic spiral wall anchors -- pre-drill the pilot holes and be careful not to drill in too far.
Then connect the two side support structures with a cross bar just under the ceiling, using quarter inch bolts with large washers to fasten the cross bars to the side supports.
It will look a little industrial, but you will avoid damaging the roof. When and if you want to take it down, you would just have to fill and paint the small holes in the walls.
Good luck! I admire your persistence.
On edit -- I see that the diagram did not "print" well. There should be at least a foot of space between the two vertical support bars on each side of the structure, to distribute the load.
_____
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 26, 2026
