RJsfishin
Jun 17, 2014Explorer
How to Load test an alternator ?
Fas idle....1200 rpm 14,4 volts 100 amp alternator
HF 500 amp carbon pile load tester connected to battery.
Using logical thinking only,........
If I gradually load the system, at what amperage should should the voltage start to drop dramatically ?
In other words, should it hold the +14 volts at an 80 amp load ?
And that would indicate a good alternator ?
Any tech help on this apprecieated
