Ropdoc's avatar
Ropdoc
How to locate leak location ?
I just found a leak into one of the LED lights. I will go up on the roof tomorrow after the storm is over. But what are the best things to look for as possible points. Other than the obvious signs of leaks. The dealer told me it could be at the opposite side of the rig.
  • If you have anything that can blow air into the interior, doing an interior pressurized leak test will turn up even a pinhole leak.
  • The leak really could be from anywhere. I've had leaks from below that drew water up through siding seams. 1st thing I'd look at is the AC Gasket and the condition of the sealant around the vents. Next check the side trim around the roof, tv antenna, and clearance lights.
    Any cracks or gaps in the sealant need to be fixed.
