maillemaker's avatar
maillemaker
How to lubricate fan bearings in furnace?
So in our 27-year-old Winnebago Warrior, we have a Suburban NT30KLT furnace.
In the last couple of years, the first time it fires up you can hear the fan bearing squalling a bit and then it quiets down. I'm sure it needs some oil. Presumably they use oil-impregnated bronze bushings in the motor assembly and I'm sure they have just dried out over the years.
I pulled the access hatch, but all you can see is the burner chambers. The squirrel cage fan is behind the heater box, and there is no access to it.
It appears the outside exhaust and intake frames screw into the side of the camper and hold the tubes tight on the furnace on the back end. I can't see anything that secures it from the front. Does it just pull out? Looks like I'd have to disconnect the gas line and the ductwork which is not going to be easy.
Any ideas?
Steve
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 17, 2025
