MrWizard
Apr 22, 2017Moderator
You need to run wire
You have to run wire to the batteries for voltage sense and amperage
You can't get amperage from the idiot light wiring it has to come from the shunt at the battery, or the shunt built into the meter, which all power in and out has to go thru the shunt to measure amps
