- Bert_the_WelderExplorer IIWhilst I freely admit to knowing sweet FA about electrical, I do question the validity of taking a devise usually used in a moving vehicle and having plenty of cool, fresh air to draw in and plopping it on a crowded work bench. That seems poor methodology to me.
- Most any RV situation the amps will be limited by the wire connecting the alternator and battery.
- MEXICOWANDERERExplorerThe more **** you stuff into an electronic control unit the more there is to go wrong. Tiny 30 and 40 horsepower sailboat motors use cutouts to stop charging if the engine doesn't have enough power to fight a current. They also use a 30 second ramp enabler to prevent cold start alternator drag down. Useless for automotive.
New motorhome electrical design is so stupid on some pushers they control voltage regulators with a remote sensing connection instead of minimizing charge cabling voltage drop.
Just as a chuckle my 2 remote rectifiers have 6 rectifiers each. They are stud type PLATING rectifiers 1,200 amp 1,675 PIV. They use a 1? wrench and have 2/0 braided leads. A 1?" hole was drilled for the stud
They weigh 2 pounds each. The heat sinks are ³/16" anodized copper. Even back then the copper cost me a hundred dollars as did the anodizing. - sjholtExplorerThose tests on the PM of the none Belmar alternator are bogus because in most motorhomes the rpm of the alternator is 3 times the crank speed so at 800rpm crank speed(idle) the alternator would be doing 2400 rpm thus cooling a lot more. and when I drive down the road at 1900 rpm the alternator is doing 5700 rpm and could be putting out 165 amps. It might burn up at that amount of amps,but hasn't yet because it never reaches that.JMHO
- MEXICOWANDERERExplorerAnyone that charges batteries in a cruising sailboat needs to invest in better ventilation. I've been aboard dozens and dozens of sloops schooners and ketches down here that raise temperatures to above 100F in salons, and galleys when charging batteries.
MOST sailboat engines feature a 2 to 1 or higher pulley to pulley ratio between the engine and alternator. Few engines run optimally at dead idle. Speed is carefully adjusted to hit the "sweet spot" which eliminates jungle drums roughness, noise and vibration.
Floor and rug drying 120vac fans can inject enough air into an engine compartment to lower air temperature as much as fifty degrees. Not theoretically. I used to haul mine as part of my tool load.
The main problem with new fashioned alternators is they have internal fans. Adapt a proper external fan and suddenly temperatures drop dramatically.
Remote rectifier bridges not only remove junction and heat sink heat but open up the slip ring end of the alternator to cooling air.
So the test with the Bosch alternator included playing with a stacked deck. The motor they used was a 1720 RPM with very little pulley advantage. See what happens at 3,000 alternator rotor RPM. The new class of rectified WYE stators allows extremely high amperage at extremely low RPM. FAR FAR FAR slower than what an automotive application can operate at. 3.5 to 1 pulley ratio is very common.
But don't get me wrong. Heat is a terrible enemy of any alternator. My Niehoff and my 50SI 24 volt units are fed cooler air. And both have anodized copper fin stacks for external rectification.
Also..........
A single group 31 battery can accept over 100 amps. A series parallel stack of 4 cheap golf car batteries will eat 120+ amps for longer than I care to state.
So the LITHIUM hook in the BALMAR ad is misleading. The entire concept is invalid.
As a designer, meaning rotor, stator and rectifier concepts makes me eligible to judge this stuff.
If a cruising sailboat alternator has to have its charging potential curtailed to prevent burning up, then it's suffering from a FATAL FLAW. Read garbage, quackery and incompetent system design. - theoldwizard1Explorer IIThe Balmar alternators and regulators are very popular with the sailing community, but they are $$$$ !!!
The video below discusses charging lithium batteries, but everything they talk about applies to lead-acid and AGM house batteries, just change some of the settings on the charge controller.
Charge LITHIUM Batteries While Driving - System Setup - Are there reports of burnt up Alternators from RV'ers installing Lithium Batteries and the Chassis charging system is not designed for Lithium? Doug
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 11, 2026
