- StirCrazyModerator
3 tons wrote:
Kinda makes me wonder, whatever happened to the minority idea (now defunct?? ..R.I.P.) that Lithium batteries (LFP’s) don’t charge any faster than FWC’s??
3 tons
:B - 3_tonsExplorer III
time2roll wrote:
My trailer charges about the same with LA or LFP. No fuse issues, no alternator issues.
I choose not to charge my 200a/h LFP from the alternator because I prefer (say, once fully charged…) not to have it maintained at 100% SOC…I suppose a switch would remedy this, but as a desert camper I’m mostly able to keep within a decent SOC range (based on usage) with just harvest alone…
3 tons - My trailer charges about the same with LA or LFP. No fuse issues, no alternator issues.
- otrfunExplorer II. .
- 3_tonsExplorer IIIKinda makes me wonder, whatever happened to the minority idea (now defunct?? ..R.I.P.) that Lithium batteries (LFP’s) don’t charge any faster than FWC’s??
3 tons - pianotunaNomad IIIBecause of the low resistance an LiFePo4 may appear to the alternator as a dead battery. So the alternator might tend to run flat out.
However, the charging wire is often rather skimpy. That probably limits the current.
Perhaps one of the folks who has Li could use a clamp on meter and measure what is going on?
I do know that at 875 amp-hours of lead acid, I was blowing a 60 amp fuse on the charging path to the house bank.
I moved to dual 50 amp automatic circuit breakers, adding a 2nd charging path as well as manual control of the isolation solenoids. I have a meter that reads to 70 amps--and then displays dashes. I saw dashes. - MDKMDKExplorer
dougrainer wrote:
Are there reports of burnt up Alternators from RV'ers installing Lithium Batteries and the Chassis charging system is not designed for Lithium? Doug
Only on the Victron video. - MDKMDKExplorer
Huntindog wrote:
pianotuna wrote:
This guy isn't all that bright,
Hi all,
https://youtu.be/jgoIocPgOug
The video offers solutions.
When an altenator is installed on a automobile, it is driven by the crankshaft pulley which is much larger. Usually a 4 to one ratio. So even at idle, it would be turning over 2000 rpm
Victron sells several "alternator protection devices" and so, have a dog in the fight. If the alternator doesn't start smoking, you won't buy their stuff to protect yours.
They also supply very little specific information about the alternator's specs, even where it came from, had it been used before, and so on. Then they connect it to a lithum battery with the same "shrouded in mystery" BMS specs. Many people choose to believe it because they've had good luck with other Victron hardware, that's understandable, and everyone always raves about it, especially on the sailing/yachting forums. I've never used any of it, and I haven't had any major problems as a result of not spending my money on their stuff.
Honestly, does anyone know anyone that burned up their alternator charging a lithium battery bank? Or burned up their own? I don't, nor can I find any internet posts that support the notion. (cue the deluge of "I know someone..." replies) - HuntindogExplorer
Hi all,
When an altenator is installed on a automobile, it is driven by the crankshaft pulley which is much larger. Usually a 4 to one ratio. So even at idle, it would be turning over 2000 rpm - MDKMDKExplorer
Old thread, good question. I have googled this, and asked for anyone with a real world experience burning up their alternator with lithium batteries to describe the event, and to date the response is usually "crickets".
Having RV issues? Connect with others who have been in your shoes.24,334 PostsLatest Activity: Nov 09, 2025
