efiguero's avatar
efiguero
"how to" on installing a 30 amp plug at your home?
So I'd like a 30 amp plug installed in my garage, is this something a DIYer can do? I was curious also if it is possible to use the wiring for an existing basic outlet to swap out the standard plug with a 30 amp plug if the breaker fuse is updated to a 30 amp fuse? Or would the wire gauge not be sufficient? Anyone do this? Thanks in advance for any pointers of suggestions.
  • I would urge you to contact a professional electrician and get the job done properly and up to code.
  • It is just that simple and your on the right track, BUT!!!!!!! Your right, the wiring is not adequate for a 30 amp outlet. You need to run a new 10 ga three wire from your breaker panel to your 30 amp location, add a 30 amp breaker to the box and a 30 amp socket to the location you want the power for your RV.
    As long as you wire it correctly.
    Go to this link and copy and PRINT it out and follow the directions!
    http://www.myrv.us/electric/
