landyacht318
Mar 13, 2015Explorer
There are a stunning array of computer fans available in all sizes. While I'd definitely remove the fan, peel off the sticker and lube the bushing, i would also snap a pic of all the specs on the fan, and try to find its ratings, then find a ball bearing fan of similar specs.
Long time back I replaced the noisy fan in my MSW inverter, with the same exact fan, when i should have researched a bit more and got a better fan.
Some designs can move more air for less noise, and usually these designs have steeper angles on the impeller blades, more scythe like blades as opposed to a straight 45 angle. Also some fans have a smaller hub and more fan blade area allowing them to move more air for less rpm and thus noise.
google 'frozen CPU'
google 'frozen CPU'
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 15, 2026
