CA_Traveler
Oct 06, 2019Explorer III
No warranty on a 2018? Sounds like bad floor or roller. But if flush floor slide that could also be involved. Have you checked the floor inside removing what ever is required to get access?
My slides can be raised when extended with a large wooden block near the end but leaving enough clearance to install SS plates above the rollers which are on the very ends. Different rig but perhaps this helps.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
