pbitschura's avatar
pbitschura
How to release drawer from glides.
Getting ready to winterize our new trailer. It's a 20220 Braxton Creek .I've located the water pump behind my kitchen drawers and that seems to be the only access. I can't find a release so I can remove the drawers and access the water lines. All I can find on the glides is BRDsupply.com and made in China. Also, there is a zone valve on the blue water line next to the pump. What is that for?
  • rk911 wrote:
    depends on the drawer. i've run across two basic types. in each there is a release on the bottom of the glide...either close to the front or farther back. they either lift up or push down. one type lifts on one side while oushing down on the opposite side.
    Found them. Thanks. Also the valve is a bypass to suck up the pink stuff.
  • depends on the drawer. i've run across two basic types. in each there is a release on the bottom of the glide...either close to the front or farther back. they either lift up or push down. one type lifts on one side while oushing down on the opposite side.
