rmdenis's avatar
rmdenis
how to remove atwood heater
I have to remove the heater in order to replace the duct pipes, which I am replacing with solid (mice proof lol). Can't disconnect gas line?? help
  • Why cannot the gas line be removed? Mine is a bit tight to get a wrench on but still it is just a pipe with fittings.
  • Ducted models are removed via outside.
    Have to unscrew/remove cover to access components.
    HERE is a service manual that covers the different models of Atwoods.
    Exploded views start on pg. 39
  • You say heater, I guess you mean the furnace, if so gas line disconnects from exterior. Look for vented cover with 4 screws attaching it to the exterior. remove the cover and you should see the gas connection, good luck with the duct hose project
Having RV issues? Connect with others who have been in your shoes.24,348 PostsLatest Activity: Jan 13, 2026
