- Horizon170Explorer
sfpcservice wrote:
Have you tried to slide the TV up or to the sides? Will it tilt at all?
THANKS,
Finally got it. Pull lever on right side DOWM.
Slide TV to the left. ------It was stuck until I bumped it rather hard.
NAME on back is AL-KO.
This is it under a new name---mine is turned 90*.
http://www.ebay.com/itm/MAX-Q-TVM-1324-LCD-TV-Bracket-Wall-Mount-Flat-Panel-Camper-Trailer-RV/272331051884?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20131003132420%26meid%3Dbe9c97b9e3c9452993aca179a1cc4a7f%26pid%3D100005%26rk%3D2%26rkt%3D6%26sd%3D322220399994 - Horizon170ExplorerYes, yes, no-----------------I wiggled it all sorts of different ways to no avail.
Maybe I didn't put enough pressure on the lever. I'll try again. - Diesel_CamperExplorerHave you tried to slide the TV up or to the sides? Will it tilt at all?
Having RV issues? Connect with others who have been in your shoes.24,321 PostsLatest Activity: Sep 29, 2025
