opnspaces
Mar 28, 2023Navigator III
Can you look up behind the damage and see what it might entail? If it's just sheet metal you could epoxy a few strips of wood to the inside then screw from the outside.
If there is floor or other structure behind the damage I would inspect very carefully before you decided to just screw it together and walk off.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
