nwoodco1
Mar 29, 2023Explorer
Mike134 wrote:prichardson wrote:
There is likely wood framing behind. If that has not been damaged the screw holes can be plugged with wood slivers and glue and the screws reset.
/\ /\ /\ /\ this Toothpicks and glue in the stripped holes
The issue is that because of the angle of impact the framing is split, so I am not sure it can be repaired to screw into.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
