1995brave
Jul 11, 2017Nomad
Just ran a tailgate backup camera in my 2012 RAM 1500. Came down the drivers side frame rail(in split loom tubing) to just in front of the gas tank(that puts you just below the back seat). Then lift up the back seat and carpeting and in the corner you will see the body plug, drill your hole there, run your cable through and seal it up good. Now you can run the cable under the door sills up to the dash. Pop the drivers side dash panel off and you will find plenty of space to run the cable all the way up to the mirror if you want.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
