Bill_Satellite
Mar 09, 2018Explorer II
If you do have an inverter then when you are not plugged in at home or running the generator you would still be able to get 120V power with the inverter turned on. We would need to know what kind of inverter and the capabilities (400 Watt, 1000 W, 2000W, etc.) and what battery/batteries you have. You may only need to add a converter and add an additional which will charge your batteries when plugged in and on generator. Your engine alternator "should" already be wired to charge this battery when driving.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 16, 2026
