Almot
Mar 10, 2018Explorer III
mauisanna wrote:
not sure any of the info for the inverter as it was installed by the previous owner. I just know that if it is off then nothing electrical in the bus works when the bus is plugged in!
This sounds more like "Converter" to me. Not Inverter. It makes 12V out of 120V, and charges the battery. If lights and other small electrical things inside the bus don't work when it's off, then your battery is dead. Or you're accidentally switching both the battery and Converter off.
Running electric kettle without generator on a single battery, you'll kill the battery in no time.
Use propane for kettle. Fridge is possible to run with 2 batteries, solar and alternator.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 16, 2026
