wopachop's avatar
wopachop
How to tell when water heater is at max?
When using the electric heating element is there a way to tell when its reached max temp and shuts off? (besides trying to listen) I keep meaning the buy an instant meat thermometer. I suppose i could test the water temp coming out the faucet. But the way the tank is designed it seems the hot water that first comes out of the top of the tank does not represent the temp of the water lower in the tank.
I notice how quickly the shower water can go from hot to cold. Seems like the tank does a good job of not letting the incoming cold water mix with the hot water at the top of the tank. Thats why simply sticking my hand under the hot water can trick ya. I did that yesterday and sure enough the water turned cold in about half the time. Thought i had waited a decent amount of time for the water to heat up.
