bighatnohorse's avatar
bighatnohorse
Explorer II
Oct 25, 2015
How to test auxiliary batteries for amperage?
I need a way to test a pair of six volt Trojan 105's wired in series and setting in my shop.
Has anyone a method of amp testing batteries that are on the bench?
I can't think of anything 12 volt that will pull a lot of current that is readily available to use as a test load.
  • guess its a matter of moving 200lbs of batteries or a 40lb tester :) either way works
  • GordonThree wrote:
    Hygrometer isn't going to read out damage to the plates.
    Go to Advance / Autozone and rent their battery load tester. It's just a box with a big resistor and a meter, should be cheap / free with a deposit.
    Or better yet, take the batteries to one of those places and ask them to test them. They will put them on a tester and run the test for you for free. Of course, they do this because they want to sell you a new battery, but not being able to do so because the problem is really elsewhere, but they are friendly and helpful none the less.
  • Hygrometer isn't going to read out damage to the plates.
  • Just like testing a 12 volt battery. A giant resistor, a period of time to apply the load, and a way to read the voltage. Oh thats right, its called a load tester.
  • Inverter load, starter motor engine disabled.
    Wluldn't an accurate hydrometer reading work?
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
